Conway polynomials of two-bridge links - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
We give necessary conditions for the Conway polynomial of a two-bridge link. We apply our conditions to the Alexander polynomial of a two-bridge knot, and obtain simple proofs of the classical theorems of Murasugi and Hartley. We also give sharp bounds for the coefficients of the Conway and Alexander polynomials of a two-bridge link. These bounds improve and generalize those of Nakanishi and Suketa. The efficiency of these conditions are compared on a large number of knots and links.
cw11d3b.pdf (246.21 Ko) Télécharger le fichier
hal-00538729 , version 1 (23-11-2010)
hal-00538729 , version 2 (02-07-2011)
hal-00538729 , version 3 (05-03-2012)
  • HAL Id : hal-00538729 , version 1
Pierre-Vincent Koseleff, Daniel Pecker. Conway polynomials of two-bridge links. 2010. ⟨hal-00538729v1⟩
216 Consultations
331 Téléchargements
