Combining Model-Driven Engineering and Cloud Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Service-orientation and model-driven engineering are two of the most dominant software engineering paradigms nowadays. This position paper explores the synergies between them and show how they can benefit from each other. In particular, the paper introduces the notion of Modeling as a Service (MaaS) as a way to provide modeling and model-driven engineering services from the cloud.
CombiningMDE-CloudComputing_2010.pdf (538.58 Ko) Télécharger le fichier
hal-00539168 , version 1 (24-11-2010)
  • HAL Id : hal-00539168 , version 1
Hugo Bruneliere, Jordi Cabot, Frédéric Jouault. Combining Model-Driven Engineering and Cloud Computing. Modeling, Design, and Analysis for the Service Cloud - MDA4ServiceCloud'10: Workshop's 4th edition (co-located with the 6th European Conference on Modelling Foundations and Applications - ECMFA 2010), Jun 2010, Paris, France. ⟨hal-00539168⟩
1123 Consultations
1285 Téléchargements
