Optimality of T-coercivity for scalar interface problems between dielectrics and metamaterials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
Some electromagnetic materials have, in a given frequency range, an effective dielectric permittivity and/or a magnetic permeability which are real-valued negative parameters when dissipation is neglected. They are usually called metamaterials. We study a scalar wave transmission problem between a classical dielectric material and a metamaterial, set in an open, bounded subset of R^d, with d = 2, 3. Our aim is to characterize occurences where the problem is well-posed within the Fredholm (or coercive + compact) framework. For that, we build some criteria, based on the geometry of the interface between the dielectric and the metamaterial. The proofs rely on localization techniques, together with the theory of T-coercivity introduced by the first and third authors and co-worker. In particular, we establish the optimality of the criteria, when the dielectric permittivity is piecewise constant.
BoCC10b-HAL.pdf (5.47 Mo) Télécharger le fichier
hal-00564312 , version 1 (08-02-2011)
hal-00564312 , version 2 (16-05-2012)
  • HAL Id : hal-00564312 , version 1
Anne-Sophie Bonnet-Ben Dhia, Lucas Chesnel, Patrick Ciarlet. Optimality of T-coercivity for scalar interface problems between dielectrics and metamaterials. 2011. ⟨hal-00564312v1⟩
Collections
ENSTA
444 Consultations
415 Téléchargements
