Thermographic analysis of fatigue dissipation properties of DP60 steel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
B. Berthel
A. Galtier
  • Fonction : Auteur
Andre Chrysochoos
This paper presents an infrared image processing developed to analyse the calorimetric manifestation associated with a fatigue test. Heat sources accompanying the fatigue mechanisms were derived from thermal data provided by an IR camera. Our experiments underlined the precocious, heterogeneous development of the dissipation sources due to fatigue. They also pointed out a linear evolution of the dissipation intensity as a function of the loading frequency.
Conf_Chrysochoos_al_Photomechanics_2006.pdf (110.39 Ko) Télécharger le fichier
hal-00572478 , version 1 (22-09-2021)
  • HAL Id : hal-00572478 , version 1
B. Berthel, A. Galtier, Bertrand Wattrisse, Andre Chrysochoos. Thermographic analysis of fatigue dissipation properties of DP60 steel. Photomecanics'01, 2006, Clermont-Ferrand, France. ⟨hal-00572478⟩
48 Consultations
15 Téléchargements
