Loss separation in soft magnetic composites - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Physics Année : 2011
We report and discuss significant results on the magnetic losses and their frequency dependence in soft magnetic composites. Two types of bonded Fe-based materials have been characterized at different inductions from dc to 10 kHz and analyzed by extending the concept of loss separation and the related statistical theory to the case of heterogeneous materials. Starting from the experimental evidence of eddy current confinement inside the individual particles, the classical loss component is calculated for given particle size distribution. Taking then into account the contribution of the experimentally determined quasistatic (hysteresis) loss, the excess loss component is obtained and quantitatively assessed. Its behavior shows that the dynamic homogenization of the magnetization process with frequency, a landmark feature of magnetic laminations, is restrained in these materials. This results into a partial offset of the loss advantage offered by the eddy current confinement.
Mots clés
article.pdf (389.48 Ko) Télécharger le fichier
hal-00584717 , version 1 (27-04-2011)
  • HAL Id : hal-00584717 , version 1
Olivier de La Barrière, Carlo Appino, Fausto Fiorillo, Ragusa Carlo, Hamid Ben Ahmed, et al.. Loss separation in soft magnetic composites. Journal of Applied Physics, 2011, 109, pp.07A317. ⟨hal-00584717⟩
389 Consultations
441 Téléchargements
