Timesheets.js: Tools for Web Multimedia - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fabien Cazenave
  • Fonction : Auteur
  • PersonId : 909310
Vincent Quint
  • Fonction : Auteur
  • PersonId : 833612
Cécile Roisin
  • Fonction : Auteur
  • PersonId : 946792
Timesheets.js is a JavaScript library for publishing multimedia web documents that take advantage of the new features of HTML5 and CSS3. The library allows web developers to extend their skills to synchronized multimedia contents. This technology has been experimented in a class where students had to implement an XSLT transformation for converting OpenOffice Impress presentations into web formats. The resulting slideshows run in web browsers thanks to the timesheets.js library.
ACMMM11.pdf (285.83 Ko) Télécharger le fichier
hal-00619396 , version 1 (06-09-2011)
  • HAL Id : hal-00619396 , version 1
Fabien Cazenave, Vincent Quint, Cécile Roisin. Timesheets.js: Tools for Web Multimedia. ACM Multimedia 2011, Nov 2011, Scottsdale, Arizona, United States. 4 p. ⟨hal-00619396⟩
477 Consultations
382 Téléchargements
