Polychronous interpretation of synoptic, a domain specific modeling language for embedded flight-software - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jérémy Buisson
Fabien Dagnat
The SPaCIFY project, which aims at bringing advances in MDE to the satellite flight software indus- try, advocates a top-down approach built on a domain-specific modeling language named Synoptic. In line with previous approaches to real-time modeling such as Statecharts and Simulink, Synoptic features hierarchical decomposition of application and control modules in synchronous block dia- grams and state machines. Its semantics is described in the polychronous model of computation, which is that of the synchronous language SIGNAL.
Synoptic_EPTCS.pdf (150.36 Ko) Télécharger le fichier
hal-00624134 , version 1 (15-09-2011)
Loïc Besnard, Thierry Gautier, Julien Ouy, Jean-Pierre Talpin, Jean-Paul Bodeveix, et al.. Polychronous interpretation of synoptic, a domain specific modeling language for embedded flight-software. FM 09 - Workshop on Formal Methods for Aerospace, Nov 2009, Eindhoven, Netherlands. pp.80-87, ⟨10.4204/EPTCS.20.9⟩. ⟨hal-00624134⟩
563 Consultations
187 Téléchargements
