Chasing a moving target from a flying UAV - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper proposes a vision-based algorithm to autonomously track and chase a moving target with a small- size flying UAV. The challenging constraints associated with the UAV flight led us to consider a density-based representation of the object to track. The proposed approach to estimate the target's position, orientation and scale, is built on a robust color- based tracker using a multi-part representation. This object tracker can handle large displacements, occlusions and account for some image noise due to partial loss of wireless video link, thanks to the use of a particle filter. The information obtained from the visual tracker is then used to control the position and yaw angle of the UAV in order to chase the target. A hierarchical control scheme is designed to achieve the tracking task. Experiments on a quad-rotor UAV following a small moving car are provided to validate the proposed approach.
Mots clés
2011_iros_teuliere.pdf (1.49 Mo) Télécharger le fichier
hal-00639702 , version 1 (09-11-2011)
  • HAL Id : hal-00639702 , version 1
C. Teuliere, L. Eck, E. Marchand. Chasing a moving target from a flying UAV. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'11, 2011, San Francisco, USA, United States. ⟨hal-00639702⟩
329 Consultations
823 Téléchargements
