Finding Optimal Formulae for Bilinear Maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We describe a unified framework to search for optimal formulae evaluating bilinear --- or quadratic --- maps. This framework applies to polynomial multiplication and squaring, finite field arithmetic, matrix multiplication, etc. We then propose a new algorithm to solve problems in this unified framework. With an implementation of this algorithm, we prove the optimality of various published upper bounds, and find improved upper bounds.
bilinear.pdf (383.85 Ko) Télécharger le fichier
hal-00640165 , version 1 (28-02-2012)
hal-00640165 , version 2 (28-02-2012)
Razvan Barbulescu, Jérémie Detrey, Nicolas Estibals, Paul Zimmermann. Finding Optimal Formulae for Bilinear Maps. International Workshop of the Arithmetics of Finite Fields, Ruhr Universitat Bochum, Jul 2012, Bochum, Germany. ⟨10.1007/978-3-642-31662-3_12⟩. ⟨hal-00640165v2⟩
526 Consultations
424 Téléchargements
