Optimal sampling for state change detection with application to the control of sleep mode - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This work considers systems with inactivity periods of unknown duration. We study the question of scheduling waking up instants in which a server can check whether the inactivity period is over. There is a cost proportional to the delay from the moment the inactivity period ends until the server discovers it, a (small) running cost while the server is away and also a cost for waking up. As an application to the problem, we consider the energy management in WiMax where inactive mobiles reduce their energy consumption by entering a sleep mode. Various standards exist which impose specific waking-up scheduling policies at wireless devices. We check these and identify optimal policies under various statistical assumptions. We show that periodic fixed vacation durations are optimal and derive the optimal period. We show that this structure does not hold for other inactivity distributions but manage to obtain some suboptimal solutions which perform strictly better than the periodic ones. We finally obtain structural properties for optimal policies for the case of arbitrary distribution of inactivity periods.
cdc-author-version.pdf (171.94 Ko) Télécharger le fichier
hal-00640984 , version 1 (12-07-2019)
Amar Prakash Azad, Sara Alouf, Eitan Altman, Vivek Borkar, Georgios Paschos. Optimal sampling for state change detection with application to the control of sleep mode. 48th IEEE Conference on Decision and Control (CDC 2009), Dec 2009, Shanghai, China. pp.1645-1650, ⟨10.1109/CDC.2009.5400669⟩. ⟨hal-00640984⟩
232 Consultations
93 Téléchargements
