The ImageCLEF 2011 plant images classification task - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
ImageCLEFs plant identification task provides a testbed for the system-oriented evaluation of tree species identification based on leaf images. The aim is to investigate image retrieval approaches in the con- text of crowdsourced images of leaves collected in a collaborative manner. This paper presents an overview of the resources and assessments of the plant identification task at ImageCLEF 2011, summarizes the retrieval approaches employed by the participating groups, and provides an anal- ysis of the main evaluation results.
plant-retrieval-overview-.pdf (6.98 Mo) Télécharger le fichier
hal-00642197 , version 1 (17-11-2011)
  • HAL Id : hal-00642197 , version 1
Hervé Goëau, Pierre Bonnet, Alexis Joly, Nozha Boujemaa, Daniel Barthélémy, et al.. The ImageCLEF 2011 plant images classification task. ImageCLEF 2011, Sep 2011, Amsterdam, Netherlands. ⟨hal-00642197⟩
922 Consultations
733 Téléchargements
