Impact of clock drifts on CAN frame response time distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Aurélien Monot
  • Fonction : Auteur
  • PersonId : 914306
Nicolas Navet
  • Fonction : Auteur
  • PersonId : 844306
The response time distributions of the frames sent on a Controller Area Network (CAN) bus are of prime interest to dimension and validate automotive electronic architectures. However, the existing work on the timing behaviour of the CAN network does not take into account that all the data exchanges between the Electronic Control Units (ECUs) are driven by different and independent clocks which are subject to clock drifts. This paper proposes a model for clock drifts and describes their impact on the CAN frame response time distributions. By implementing the clock drifts in a CAN simulation tool, we show experimentally that the response time distributions converge, for drift values chosen randomly within the same range on all ECUs, whatever the initial phasings between the sending nodes. Furthermore, we show that, as a result of the clock drifts, the situations leading to the worst case response times are transient.
indusPaper.pdf (1004.49 Ko) Télécharger le fichier
PosterETFAlast.pdf (14.17 Mo) Télécharger le fichier
Format : Autre
hal-00643314 , version 1 (21-11-2011)
  • HAL Id : hal-00643314 , version 1
Aurélien Monot, Nicolas Navet, Bernard Bavoux. Impact of clock drifts on CAN frame response time distributions. 16th IEEE International Conference on Emerging Technologies and Factory Automation - ETFA 2011, IEEE, Sep 2011, Toulouse, France. ⟨hal-00643314⟩
128 Consultations
240 Téléchargements
