On Constructing Homomorphic Encryption Schemes from Coding Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce a generic construction principle for homomorphic encryption schemes based on coding theory. These possess several non-standard positive features. First, they are not restricted to linear homomorphism but allow for evaluating multivariate polynomials up to a fixed (but arbitrary) degree μ on encrypted field elements. Second, they can be instantiated with various error correcting codes, even for codes with poor correcting capabilities. Third, depending on the deployed code, one can achieve very efficient schemes. As a concrete example, we present an instantiation based on Reed-Muller codes where for μ = 2 and μ = 3 and security levels between 80 and 128 bits, all operations take less than a second (after some pre-computation). However, our analysis reveals also limitations on this approach. For structural reasons, such schemes cannot be public-key, allow for a limited number of fresh encryptions only, and cannot be combined with the bootstrapping technique. We argue why such schemes are nonetheless useful in certain application scenarios and discuss possible directions on how to overcome these issues.
CodeBasedHomEnc.pdf (194.41 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00643774 , version 1 (22-11-2011)
Frederik Armknecht, Daniel Augot, Ludovic Perret, Ahmad-Reza Sadeghi. On Constructing Homomorphic Encryption Schemes from Coding Theory. 13th IMA International Conference on Cryptography and Coding, Institute of Mathematics and its Applications (IMA), Dec 2011, Oxford, United Kingdom. pp.23-40, ⟨10.1007/978-3-642-25516-8_3⟩. ⟨hal-00643774⟩
678 Consultations
745 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
