Wide Frequency Band Numerical Approaches for Multiple Scattering Problems by Disks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Algorithms and Computational Technology Année : 2012
Efficient, robust and accurate algorithms are proposed for solving the multiple scattering problem by M circular obstacles for the whole spectrum of frequency. The representation of the solution is based on an integral equation formulation next solved by using Fourier basis. Numerical examples are provided to show that the approaches are efficient.
ART_JACT_HAL.pdf (553.05 Ko) Télécharger le fichier
hal-00644373 , version 1 (26-02-2013)
Xavier Antoine, Karim Ramdani, Bertrand Thierry. Wide Frequency Band Numerical Approaches for Multiple Scattering Problems by Disks. Journal of Algorithms and Computational Technology, 2012, 6 (2), pp.241-260. ⟨10.1260/1748-3018.6.2.241⟩. ⟨hal-00644373⟩
654 Consultations
155 Téléchargements
