Method, Models and Tools for CAD-CAE Integration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Recent Patents on Mech. Eng Année : 2010
Okba Hamri
  • Fonction : Auteur
  • PersonId : 915255
Bianca Falcidieno
  • Fonction : Auteur
Franca Giannini
  • Fonction : Auteur
  • PersonId : 861716
Computer Aided Design (CAD) and Computer Aided Engineering (CAE) are two significantly different disciplines, and hence they require different shape models representations. As a result, models generated by CAD systems often need to be submitted to shape transformations for Finite Element Analysis (FEA). In this paper, a new approach is proposed to ease integration between CAD and CAE also outlining some patents. It is based on new shape representation called 'mixed shape representation' that supports simultaneously a B-Rep (manifold and non-manifold) and a polyhedral representation to create a robust link between the CAD and CAE environments. Both representations are maintained through the same topology description called the High Level Topology (HLT), which represents a common requirement for simulation model preparation. An innovative approach to FE model preparation based on the mixed representation is presented in this paper. Thus a set of necessary tools is associated to the mixed shape representation, which contributes to reduce, as much as possible, the time of a model preparation process.
Fichier non déposé
hal-00645345 , version 1 (27-11-2011)
Okba Hamri, Jean-Claude Léon, Bianca Falcidieno, Franca Giannini. Method, Models and Tools for CAD-CAE Integration. Recent Patents on Mech. Eng, 2010, 3 (2), pp.106-130. ⟨10.2174/1874477X11003020106⟩. ⟨hal-00645345⟩
203 Consultations
0 Téléchargements
