Adaptation knowledge discovery for cooking using closed itemset extraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Emmanuelle Gaillard
  • Fonction : Auteur
  • PersonId : 765221
  • IdRef : 197149065
Jean Lieber
Emmanuel Nauer
This paper is about the adaptation knowledge (\ak) discovery for the \taaable system, a case-based reasoning system that adapts cooking recipes to user constraints. The \ak comes from the interpretation of closed itemsets (\cis) whose items correspond to the ingredients that have to be removed, kept, or added. An original approach is proposed for building the context on which \ci extraction is performed. This approach focuses on a restrictive selection of objects and on a specific ranking based on the form of the \cis. Several experimentations are proposed in order to improve the quality of the \ak being extracted and to decrease the computation time. This chain of experiments can be seen as an iterative knowledge discovery process: the analysis following each experiment leads to a more sophisticated experiment until some concrete and useful results are obtained.
CLA_2011.Definitif.pdf (435.26 Ko) Télécharger le fichier
hal-00646732 , version 1 (30-11-2011)
  • HAL Id : hal-00646732 , version 1
Emmanuelle Gaillard, Jean Lieber, Emmanuel Nauer. Adaptation knowledge discovery for cooking using closed itemset extraction. The Eighth International Conference on Concept Lattices and their Applications - CLA 2011, Oct 2011, Nancy, France. ⟨hal-00646732⟩
250 Consultations
149 Téléchargements
