Software Metrics for Package Remodularisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
There is a plethora of software metrics \cite{Lore94a, Fent96a, Hend96a, Han00a, Lanz06a} and a large amount of research articles. Still there is a lack for a serious and practically-oriented evaluation of metrics. Often metrics lack the property that the software reengineer or quality expert can easily understand the situation summarized by the metrics. In particular, since the exact notion of coupling and cohesion is complex, a particular focus on such point is important. In the first chapter of the present document, we present a list of software metrics, that are commonly used to measure object-oriented programs. In the second chapter we present our proposition for package metrics that capture package aspects such as information hiding and change impact limits.
Duca11b-Cutter-deliverable11-SoftwareMetrics.pdf (417.1 Ko) Télécharger le fichier
hal-00646878 , version 1 (01-12-2011)
  • HAL Id : hal-00646878 , version 1
Stéphane Ducasse, Nicolas Anquetil, Muhammad Usman Bhatti, Andre Cavalcante-Hora. Software Metrics for Package Remodularisation. [Research Report] 2011. ⟨hal-00646878⟩
370 Consultations
479 Téléchargements
