On the Equivalence of Sudan-Decoding and Decoding via Virtual Extension to an Interleaved Reed-Solomon Code
In this paper we investigate two new decoding schemes for Reed-Solomon codes, which allow to decode beyond half the minimum distance. One is Sudan's list-decoding principle, based on interpolation with a degree-restricted bivariate polynomial. We show a syndrome-based approach of it. We compare Sudan's procedure with a scheme that is based on an extension to Interleaved Reed-Solomon codes. We present theoretical parallels and outline both algorithms in a unique comparable way. Furthermore, we show the connection of both schemes to the classical Linear Feedback Shift Register analysis. Afterwards, we compare the performance of the considered schemes.
