Next Generation LearnLib
The Next Generation LearnLib (NGLL) is a framework for model-based construction of dedicated learning solutions on the basis of extensible component libraries, which comprise various methods and tools to deal with realistic systems including test harnesses, reset mechanisms and abstraction/refinement techniques. Its construction style allows application experts to control, adapt, and evaluate complex learning processes with minimal programming expertise.
