Global vs. Per-Domain Monitoring of Multi-Domain Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Emna Salhi
  • Fonction : Auteur
  • PersonId : 881845
Samer Lahoud
Bernard Cousin
Mutli-domain monitoring aims at guaranteeing QoS for services crossing several domains. It is often desirable to perform global monitoring to guarantee end-to-end QoS for services across domains and to reduce the monitoring cost. However, global monitoring might be infeasible due to confidentiality constraints. The alternative solution is to perform per-domain monitoring. In this work, we propose to evaluate global and per-domain monitoring techniques. For this end, we study the properties of multi-domain networks and the requirements of multi-domain monitoring. We formulate the problem as an Integer Linear Program (ILP). We show that it is a Nondeterministic Polynomial Time Hard (NP-Hard) problem, and therefore, we devise a heuristic that meets multi-domain properties. We show that confidentiality is far from being the only constraint to global multi-domain monitoring. In our evaluation, the confidentiality constraint has been relaxed, in order to investigate other performance metrics; namely, the monitoring cost, the quality of monitored paths, the anomaly detection delays, and the fairness of monitoring load distribution among domains. Simulation results on random topologies show that per-domain monitoring outperforms global monitoring for all these metrics, except the monitoring cost that is slightly lower for global monitoring.
LCN_11.pdf (429.51 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00648165 , version 1 (05-12-2011)
  • HAL Id : hal-00648165 , version 1
Emna Salhi, Samer Lahoud, Bernard Cousin. Global vs. Per-Domain Monitoring of Multi-Domain Networks. The 36th IEEE Conference on Local Computer Networks (LCN), Oct 2011, Bonn, Germany. ⟨hal-00648165⟩
134 Consultations
101 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
