New interface
Conference papers
Modélisation par développements asymptotiques raccordés d'une structure présentant une fine couche d'inclusions rigides disposées périodiquement
Abstract : We consider a 3D structure containing an epsilon-thin layer of epsilon-periodically distributed rigid inclusion. In order to model the elastic behavior of this multiscale structure, we propose an efficient and robust method based on the matched asymptotic expansion. The limit problem, characterized by specific transmission conditions, is numerically solved by an adapted domain decomposition method.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00648615
Contributor : Marina Vidrascu Connect in order to contact the contributor
Submitted on : Tuesday, December 6, 2011 - 10:28:11 AM
Last modification on : Tuesday, October 25, 2022 - 4:23:35 PM
Long-term archiving on: : Wednesday, March 7, 2012 - 2:30:50 AM
File
Hendili1.pdf
Identifiers
  • HAL Id : hal-00648615, version 1
Citation
Giuseppe Geymonat, Sofiane Hendili, Françoise Krasucki, Marina Vidrascu. Modélisation par développements asymptotiques raccordés d'une structure présentant une fine couche d'inclusions rigides disposées périodiquement. CFM 2011 - 20 ème congrès français de mécanique, Aug 2011, Besançon, France. ⟨hal-00648615⟩
Share
Metrics
Record views
140
Files downloads
385
