Stereoscopic Focus Mismatch Monitoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We detect focus mismatch between views of a stereoscopic pair. First, we compute a dense disparity map. Then, we use a measure to compare focus in both images. Finally we use robust statistics to find which images zones have different focus. We show the results on the original images.
Mots clés
CVMP2011_FocusMissmatchMonitoring2b.pdf (8.01 Mo) Télécharger le fichier
CVMP2011FocusMismatch.pdf (7.21 Mo) Télécharger le fichier
Format : Autre
hal-00651843 , version 1 (14-12-2011)
  • HAL Id : hal-00651843 , version 1
Sergi Pujades, Frédéric Devernay. Stereoscopic Focus Mismatch Monitoring. CVMP - European Conference on Visual Media Production, The Foundry, Nov 2011, London, United Kingdom. 1p. ⟨hal-00651843⟩
201 Consultations
112 Téléchargements
