A Stereoscopic Movie Player with Real-Time Content Adaptation to the Display Geometry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
3D shape perception in a stereoscopic movie depends on several depth cues, including stereopsis. For a given content, the depth perceived from stereopsis highly depends on the camera setup as well as on the display size and distance. This can lead to disturbing depth distortions such as the cardboard effect or the puppet theater effect. As more and more stereoscopic 3D content is produced in 3D (feature movies, documentaries, sports broadcasts), a key point is to get the same 3D experience on any display. For this purpose, perceived depth distortions can be resolved by performing view synthesis. We propose a real time implementation of a stereoscopic player based on the open-source software Bino, which is able to adapt a stereoscopic movie to any display, based on user-provided camera and display parameters.
duchene-sda2012.pdf (1.1 Mo) Télécharger le fichier
hal-00657928 , version 1 (09-01-2012)
Sylvain Duchêne, Martin Lambers, Frédéric Devernay. A Stereoscopic Movie Player with Real-Time Content Adaptation to the Display Geometry. SD&A 2012 - Stereoscopic Displays and Applications XXIII, SPIE, Jan 2012, San Francisco, United States. pp.82882Q - 82882Q:8, ⟨10.1117/12.908741⟩. ⟨hal-00657928⟩
268 Consultations
647 Téléchargements
