TEI-based representation of the PEER metadata profile - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
In the context of rapid growth of institutional repositories, the PEER project (www.peerproject.eu) has been set up to monitor the effects of systematic archiving of author's final peer-reviewed manuscript over time. This document describes the output interchange that was tuned for the PEER Depot for the integration and distribution of the metadata information provided by publishers within the PEER project. It is based on the TEI's Guidelines for Text Encoding and Interchange (P5), with some additional constraints intended to make the corresponding information structures univocally interpretable.
PEER_metadata_profile.pdf (776 Ko) Télécharger le fichier
hal-00659856 , version 1 (13-01-2012)
  • HAL Id : hal-00659856 , version 1
Laurent Romary, Maud Medves. TEI-based representation of the PEER metadata profile. 2012. ⟨hal-00659856⟩
Collections
INRIA INRIA2
237 Consultations
197 Téléchargements
