Solving multi-stage stochastic mixed integer linear programs by the dual dynamic programming approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
We consider a model of medium-term commodity contracts management. Randomness takes place only in the prices on which the commodities are exchanged, whilst state variable is multi-dimensional, and decision variable is integer. In our previous article, we proposed an algorithm based on the quantization of random process and a dual dynamic programming type approach to solve the continuous relaxation problem. In this paper, we study the multi-stage stochastic mixed integer linear program (SMILP) and show the difficulty when using dual programming type algorithm. We propose an approach based on the cutting plane method combined with the algorithm in our previous article, which gives an upper and a lower bound of the optimal value and a sub-optimal integer solution. Finally, a numerical test on a real problem in energy market is provided.
RR-7868.pdf (879.68 Ko) Télécharger le fichier
hal-00663267 , version 1 (26-01-2012)
  • HAL Id : hal-00663267 , version 1
Zhihao Cen. Solving multi-stage stochastic mixed integer linear programs by the dual dynamic programming approach. [Research Report] RR-7868, INRIA. 2012. ⟨hal-00663267⟩
278 Consultations
154 Téléchargements
