DREAM2S: Deformable Regions Driven by an Eulerian Accurate Minimization Method for Image and Video Segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2003
This paper deals with image and video segmentation using active contours.We propose a general form for the energy functional related to region-based active contours.We compute the associated evolution equation using shape derivation tools and accounting for the evolving region-based terms. Then we apply this general framework to compute the evolution equation from functionals that include various statistical measures of homogeneity for the region to be segmented. Experimental results show that the determinant of the covariance matrix appears to be a very relevant tool for segmentation of homogeneous color regions. As an example, it has been successfully applied to face segmentation in real video sequences.
IJCV-03.pdf (1.38 Mo) Télécharger le fichier
hal-00664596 , version 1 (31-01-2012)
  • HAL Id : hal-00664596 , version 1
Stéphanie Jehan-Besson, Michel Barlaud, Gilles Aubert. DREAM2S: Deformable Regions Driven by an Eulerian Accurate Minimization Method for Image and Video Segmentation. International Journal of Computer Vision, 2003, 53, pp.45-70. ⟨hal-00664596⟩
175 Consultations
250 Téléchargements
