Software Implementation vs. Hardware Implementation: The Avionic Test System Case-Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2012
This paper presents a development methodology that helps designers to map efficiently applications onto a heterogeneous CPU/FPGA system. An industrial case study is presented and aims at meeting performance and real-time requirements with the help of our architecture capabilities and avionic model parallelization. Different avionic model implementations will be presented in order to explain how to find the best trade-off between performance and design-time.
ASPLOS-AFONSO.pdf (214.15 Ko) Télécharger le fichier
hal-00665162 , version 1 (01-02-2012)
  • HAL Id : hal-00665162 , version 1
George Afonso, Rabie Ben Atitallah, Jean-Luc Dekeyser. Software Implementation vs. Hardware Implementation: The Avionic Test System Case-Study. ASPLOS, Mar 2012, London, United Kingdom. ⟨hal-00665162⟩
272 Consultations
1897 Téléchargements
