1€ Filter: A Simple Speed-based Low-pass Filter for Noisy Input in Interactive Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The 1€ filter ("one Euro filter") is a simple algorithm to filter noisy signals for high precision and responsiveness. It uses a first order low-pass filter with an adaptive cutoff frequency: at low speeds, a low cutoff stabilizes the signal by reducing jitter, but as speed increases, the cutoff is increased to reduce lag. The algorithm is easy to implement, uses very few resources, and with two easily understood parameters, it is easy to tune. In a comparison with other filters, the 1€ filter has less lag using a reference amount of jitter reduction.
CHI2012-casiez.pdf (241.88 Ko) Télécharger le fichier
Format : Figure, Image
hal-00670496 , version 1 (17-02-2012)
Géry Casiez, Nicolas Roussel, Daniel Vogel. 1€ Filter: A Simple Speed-based Low-pass Filter for Noisy Input in Interactive Systems. CHI'12, the 30th Conference on Human Factors in Computing Systems, May 2012, Austin, United States. pp.2527-2530, ⟨10.1145/2207676.2208639⟩. ⟨hal-00670496⟩
1778 Consultations
18186 Téléchargements
