Usable developer-oriented Functionality Composition Language (UFCL): a Proposal for Semantic Description and Dynamic Composition of Services and Service Factories - Archive ouverte HAL Access content directly
Conference Papers Year : 2008
This paper presents a Usable developer-oriented Functionality Composition Language (UFCL) designed for ubiquitous systems developers. Easy to write, this language is used to semantically describe functionalities implemented by services in a service oriented architecture where each service exposes its own description. Service factories can also be described using UFCL: a factory defines an abstract composition pattern and is able to instantiate product services on demand. This paper also describes UFCL compilation that makes it possible to reason about functionalities exposed by services and factories.
Emonet08.pdf (87.62 Ko) Télécharger le fichier
Dates and versions
hal-00670655 , version 1 (15-02-2012)
Identifiers
  • HAL Id : hal-00670655 , version 1
Cite
Rémi Emonet, Dominique Vaufreydaz. Usable developer-oriented Functionality Composition Language (UFCL): a Proposal for Semantic Description and Dynamic Composition of Services and Service Factories. 4th IET International Conference on Intelligent Environments, Jul 2008, Seattle, United States. pp.1-8. ⟨hal-00670655⟩
175 View
120 Download
Share
