Monte Carlo approximations of the Neumann problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Monte Carlo Methods and Applications Année : 2013
We introduce Monte Carlo methods to compute the solution of elliptic equations with pure Neumann boundary conditions. We first prove that the solution obtained by the stochastic representation has a zero mean value with respect to the invariant measure of the stochastic process associated to the equation. Pointwise approximations are computed by means of standard and new simulation schemes especially devised for local time approximation on the boundary of the domain. Global approximations are computed thanks to a stochastic spectral formulation taking into account the property of zero mean value of the solution. This stochastic formulation is asymptotically perfect in terms of conditioning. Numerical examples are given on the Laplace operator on a square domain with both pure Neumann and mixed Dirichlet-Neumann boundary conditions. A more general convection-diffusion equation is also numerically studied.
Maire_Tanre_MCMA2013_001_revised.pdf (451.11 Ko) Télécharger le fichier
hal-00677529 , version 1 (21-03-2012)
hal-00677529 , version 2 (27-08-2013)
Sylvain Maire, Etienne Tanré. Monte Carlo approximations of the Neumann problem. Monte Carlo Methods and Applications, 2013, 19 (3), pp.201-236. ⟨10.1515/mcma-2013-0010⟩. ⟨hal-00677529v2⟩
494 Consultations
1020 Téléchargements
