The Byzantine Brides Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
We investigate the hardness of establishing as many stable marriages (that is, marriages that last forever) in a population whose memory is placed in some arbitrary state with respect to the considered problem, and where traitors try to jeopardize the whole process by behaving in a harmful manner. On the negative side, we demonstrate that no solution that is completely insensitive to traitors can exist, and we propose a protocol for the problem that is optimal with respect to the traitor containment radius.
report.pdf (359.05 Ko) Télécharger le fichier
hal-00679520 , version 1 (15-03-2012)
Swan Dubois, Sébastien Tixeuil, Nini Zhu. The Byzantine Brides Problem. [Research Report] ???. 2012. ⟨hal-00679520⟩
101 Consultations
461 Téléchargements
