Harmonic Knots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
Harmonic Knots
The harmonic knot $H(a,b,c)$ is parameterized as $K(t)= (T_a(t) ,T_b (t), T_c (t))$ where $a$, $b$ and $c$ are relatively coprime integers and $T_n$ is the degree $n$ Chebyshev polynomial of the first kind. We classify the harmonic knots $H(a,b,c)$ for $ a \le 4$. We show that the knot $H(2n-1, 2n, 2n+1)$ is isotopic to $H(4,2n-1, 2n+1)$ (up to mirror symmetry). We study the knots $H(5,n,n+1)$ and give a table of the simplest harmonic knots.
h4g4.pdf (496.02 Ko) Télécharger le fichier
hal-00680746 , version 1 (20-03-2012)
hal-00680746 , version 2 (19-09-2014)
Pierre-Vincent Koseleff, Daniel Pecker. Harmonic Knots. 2012. ⟨hal-00680746v1⟩
346 Consultations
325 Téléchargements
