Preprints, Working Papers, ...
High order asymptotics for the electromagnetic scattering from thin periodic layers : the 3D Maxwell case
Abstract : This work deals with the scattering of electromagnetic waves by a thin periodic layer made of an array of regularly-spaced obstacles. The size of the obstacles and the spacing between two consecutive obstacles are of the same order $\delta$, which is much smaller than the wavelength of the incident wave. We provide a complete description of the asymptotic behavior of the solution with respect to the small parameter $\delta$: we use a method that mixes matched asymptotic expansions and homogenization techniques. We pay particular attention to the construction of the near field terms. Indeed, they satisfy electrostatic problems posed in an infinite 3D strip that require a careful analysis. Error estimates are carried out to justify the accuracy of our expansion
Document type :
Complete list of metadata
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/hal-00682358
Contributor : Bérangère Delourme Connect in order to contact the contributor
Submitted on : Friday, January 3, 2014 - 5:32:43 PM
Last modification on : Wednesday, October 27, 2021 - 2:50:36 PM
Long-term archiving on: : Saturday, April 8, 2017 - 10:47:43 AM
File
DelourmeAsymptotique3D.pdf
Identifiers
  • HAL Id : hal-00682358, version 2
Citation
Bérangère Delourme. High order asymptotics for the electromagnetic scattering from thin periodic layers : the 3D Maxwell case. 2014. ⟨hal-00682358v2⟩
Share
Metrics
Record views
324
Files downloads
267
