Visual Mapping of Program Components to Resources Representation: a 3D Analysis of Grid Parallel Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Highly distributed systems such as Grids are usually interconnected by a hierarchical organization of different types of network. This strong network hierarchy influences directly the behavior of parallel applications. In order to obtain a good understanding of parallel application's behavior, the performance analysis must take into account a correspondence between application and network characteristics. This paper presents a novel way to analyze parallel applications, by using a three dimensional visualization and a technique to visually map the application's components to the used resources. This mapping technique is able to handle different types of resources description: different system logical organizations and the description of the network or system interconnection in different levels. The technique, implemented in our prototype Triva, is evaluated through a series of visual representations of the monitoring data obtained through real executions of parallel applications in a grid. The resulting visualizations enable an alternative and powerful way to view and understand various aspects of application behavior together with the network topology.
Fichier non déposé
hal-00684525 , version 1 (02-04-2012)
Lucas Mello Schnorr, Philippe Olivier Alexandre Navaux, Guillaume Huard. Visual Mapping of Program Components to Resources Representation: a 3D Analysis of Grid Parallel Applications. SBAC-PAD '09: Proceedings of the 21st International Symposium on Computer Architecture and High Performance Computing, Oct 2009, Sao Paulo, Brazil. ⟨10.1109/SBAC-PAD.2009.10⟩. ⟨hal-00684525⟩
163 Consultations
0 Téléchargements
