A $\tilde O(n^2)$ Time-Space Trade-off for Undirected s-t Connectivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
We propose a family of randomized algorithms for undirected s-t-connectivity which achieve a time-space product of $S\cdot T = \tilde O(n^2)$ for a graph with $n$ nodes and $m$ edges (where the $\tilde O$-notation disregards poly-logarithmic terms). In particular, we obtain a log-space algorithm which solves s-t-connectivity faster than the random walk, as well as an algorithm running in time $\O(n+m)$ which is, in general, more space-efficient than BFS or DFS. The algorithms rely on a new Monte-Carlo type walk on graphs, which is then combined with the landmark-based scheme of Broder et al. (1994).
fastrw.pdf (224.54 Ko) Télécharger le fichier
hal-00685373 , version 1 (05-04-2012)
hal-00685373 , version 2 (13-04-2012)
hal-00685373 , version 3 (10-07-2012)
Adrian Kosowski. A $\tilde O(n^2)$ Time-Space Trade-off for Undirected s-t Connectivity. 2012. ⟨hal-00685373v2⟩
497 Consultations
268 Téléchargements
