Checking the Realizability of BPMN 2.0 Choreographies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Choreographies allow business and service architects to specify with a global perspective the requirements of applications built over distributed and interacting software entities. While being a standard for the abstract specification of business workflows and collaboration between services, the Business Process Modeling Notation (BPMN) has only been recently extended into BPMN 2.0 to support an interaction model of choreography, which, as opposed to interconnected interface models, is better suited to top-down development processes. An important issue with choreographies is realizability, i.e., whether peers obtained via projection from a choreography interact as prescribed in the choreography requirements. In this work, we propose a realizability checking approach for BPMN 2.0 choreographies. Our approach is formally grounded on a model transformation into the LOTOS NT process algebra and the use of equivalence checking. It is also completely tool-supported through interaction with the Eclipse BPMN 2.0 editor and the CADP process algebraic toolbox.
PS-SAC12.pdf (536.55 Ko) Télécharger le fichier
hal-00685393 , version 1 (05-04-2012)
  • HAL Id : hal-00685393 , version 1
Pascal Poizat, Gwen Salaün. Checking the Realizability of BPMN 2.0 Choreographies. 27th Symposium On Applied Computing (SAC 2012), Mar 2012, Italy. pp.1927-1934. ⟨hal-00685393⟩
393 Consultations
550 Téléchargements
