An hierarchical approach for model-based classification of SAR images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose an unsupervised classification algorithm for high resolution Synthetic Aperture Radar (SAR) images based on Classification Expectation-Maximization (CEM). We combine the CEM algorithm with the hierarchical agglomeration strategy and a model order selection criterion called Integrated Completed Likelihood (ICL) to get rid of the initialization and the model order selection problems of the EM algorithm. We exploit a mixture of Nakagami densities for amplitudes and a Multinomial Logistic (MnL) latent model for class labels to obtain spatially smooth class segments. We test our algorithm on TerraSAR-X data.
siu2012SAR.pdf (741.77 Ko) Télécharger le fichier
hal-00686658 , version 1 (10-04-2012)
  • HAL Id : hal-00686658 , version 1
Koray Kayabol, Josiane Zerubia. An hierarchical approach for model-based classification of SAR images. 20th Signal Processing and Communications Applications Conference, Apr 2012, Mugla, Turkey. ⟨hal-00686658⟩
Collections
INRIA INRIA2
122 Consultations
190 Téléchargements
