Management of Services Based on a Semantic Description Within the GRID-TLSE Project - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
The goal of the GRID-TLSE Project is to design an expert site that provides an easy access to a number of tools allowing comparative analysis of sparse matrix packages on a user-submitted problem, as well as on particular matrices from the matrix collection also available on the site. When making available a large amount of software over a computational Grid, facilitating its deployment and its exploitation become crucial. Within the GRID-TLSE Project, we use a software component approach based on a high level semantic description of the scientific computing services. In this paper, we focus on one aspect of this description of the computational services: the use of meta-data called abstract parameters. Our approach allows the automatic discovery and the exploitation of new services throught the concept of scenario.
Autre [cs.OH]
hal-00689156 , version 1 (19-04-2012)
Patrick Amestoy, Michel Daydé, Christophe Hamerling, Marc Pantel, Chiara Puglisi-Amestoy. Management of Services Based on a Semantic Description Within the GRID-TLSE Project. VECPAR'06, Jul 2006, Rio de Janeiro, Brazil. pp.634-643, ⟨10.1007/978-3-540-71351-7_50⟩. ⟨hal-00689156⟩
58 Consultations
0 Téléchargements
