Journal articles
Spurious velocities in the steady flow of an incompressible fluid subjected to external forces
Abstract : We show that a non physical velocity may appear in the numerical computation of the flow of an incompressible fluid subjected to external forces. A distorted mesh and the use of a numerical method which does not rigorously ensure the incompressibility condition turn out to be responsible for this phenomenon. We illustrate it with numerical examples and we propose a projection method which improves the results.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00690238
Contributor : Jean-Frédéric Gerbeau Connect in order to contact the contributor
Submitted on : Sunday, April 22, 2012 - 4:05:34 PM
Last modification on : Friday, February 4, 2022 - 3:10:46 AM
Links full text
Identifiers
Collections
Citation
Jean-Frédéric Gerbeau, Claude Le Bris, Michel Bercovier. Spurious velocities in the steady flow of an incompressible fluid subjected to external forces. International Journal for Numerical Methods in Fluids, Wiley, 1997, 25 (6), pp.679-695. ⟨10.1002/(SICI)1097-0363(19970930)25:6<679::AID-FLD582>3.0.CO;2-Q⟩. ⟨hal-00690238⟩
Share
Metrics
Record views
138
