HR SPIV for dynamical system construction
Specific experiments of High Repetition Stereoscopic PIV were carried out in the high Reynolds number flat plate turbulent boundary layer of the Laboratoire de Mécanique de Lille (LML) wind tunnel. This experiment was done in the frame of the WALLTURB European project. The planes under study were parallel to the wall located at 50 and 100 wall units. As the flow is time resolved, space-time correlations are computed.
