Classifying French Verbs Using French and English Lexical Resources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a novel approach to the automatic acquisition of a Verbnet like classification of French verbs which involves the use (i) of a neural clustering method which associates clusters with features, (ii) of several supervised and unsupervised evaluation metrics and (iii) of various existing syntactic and semantic lexical resources. We evaluate our approach on an established test set and show that it outperforms previous related work with an F-measure of 0.70.
final.pdf (105.46 Ko) Télécharger le fichier
poster.pdf (257.22 Ko) Télécharger le fichier
Format : Autre
hal-00690484 , version 1 (27-08-2012)
  • HAL Id : hal-00690484 , version 1
Ingrid Falk, Claire Gardent, Jean-Charles Lamirel. Classifying French Verbs Using French and English Lexical Resources. The 50th annual meeting of the Association for Computational Linguistics - ACL'12, The Association for Computational Linguistics (ACL), Jul 2012, Jeju, South Korea. pp.854--863. ⟨hal-00690484⟩
174 Consultations
351 Téléchargements
