Numerical Treatment of Defective Boundary Conditions for the Navier-Stokes Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Numerical Analysis Année : 2002
Luca Formaggia
  • Fonction : Auteur
Fabio Nobile
Alfio Quarteroni
  • Fonction : Auteur
  • PersonId : 828810
We present a formulation for accommodating defective boundary conditions for the incompressible Navier-Stokes equations where only averaged values are prescribed on measurable portion of the boundary. In particular we consider the case where the average mass flux is imposed on several domain sections. This methodology has an interesting application in the numerical simulation of flow in blood vessels, when only a reduced set of boundary data are generally available for the upstream and downstream sections.
Fichier non déposé
hal-00691930 , version 1 (27-04-2012)
Luca Formaggia, Jean-Frédéric Gerbeau, Fabio Nobile, Alfio Quarteroni. Numerical Treatment of Defective Boundary Conditions for the Navier-Stokes Equations. SIAM Journal on Numerical Analysis, 2002, 40 (1), pp.376-401. ⟨10.1137/S003614290038296X⟩. ⟨hal-00691930⟩
1411 Consultations
0 Téléchargements
