Comparing Lustre Performance using Myricom 10G Dual Protocol NICs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Atchley Scott
  • Fonction : Auteur
Brice Goglin
In this paper, we look at how Lustre performs using Myricom's 10 Gb/s NICs. Lustre clients and servers can use these programmable NICs in either native Ethernet mode or in Myrinet mode. Lustre provides metrics for measuring metadata retrieval (small message) performance as well as for bulk read and write operations. We show that with multiple clients Lustre can achieve 95% of line-rate performance using Ethernet (TCP) when reading but only 50% when writing. We show that Lustre achieves a 95% of line-rate with a single client when using the NIC in Myrinet mode. In both cases, Lustre can serve up to 45,000 metadata requests per second using multiple clients.
lustre-myri10g.pdf (605.88 Ko) Télécharger le fichier
hal-00691977 , version 1 (27-04-2012)
  • HAL Id : hal-00691977 , version 1
Atchley Scott, Brice Goglin. Comparing Lustre Performance using Myricom 10G Dual Protocol NICs. [Research Report] 2006, pp.25. ⟨hal-00691977⟩
Collections
LARA
86 Consultations
313 Téléchargements
