ANTESCOFO: Anticipatory Synchronization and Control of Interactive Parameters in Computer Music. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Antescofois a modular anticipatory score following system that holds both instrumental and electronic scores together and is capable of executing electronic scores in synchronization with a live performance and using various controls over time. In its very basic use, it is a classical score following system, but in advanced use it enables concurrent representation and recognition of different audio descriptors (rather than pitch), control over various time scales used in music writing, and enables temporal interaction between the performance and the electronic score. Antescofo comes with a simple score language for flexible writing of time and interaction in computer music.
Mots clés
ArshiaCont_ICMC2008_3.pdf (270.55 Ko) Télécharger le fichier
hal-00694803 , version 1 (06-05-2012)
  • HAL Id : hal-00694803 , version 1
Arshia Cont. ANTESCOFO: Anticipatory Synchronization and Control of Interactive Parameters in Computer Music.. International Computer Music Conference (ICMC), Aug 2008, Belfast, Ireland. pp.33-40. ⟨hal-00694803⟩
654 Consultations
897 Téléchargements
