FIVER: A Finite Volume Method Based on Exact Two-Phase Riemann Problems and Sparse Grids for Multi-Material Flows with Large Density Jumps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2012
A robust finite volume method for the solution of high-speed compressible flows in multi-material domains involving arbitrary equations of state and large density jumps is presented. The global domain of interest can include a moving or deformable subdomain that furthermore may undergo topological changes due to, for example, crack propagation. The key components of the proposed method include: (a) the definition of a discrete surrogate material interface, (b) the computation of a reliable approximation of the fluid state vector on each side of a discrete material interface via the construction and solution of a local, exact, two-phase Riemann problem, (c) the algebraic solution of this auxiliary problem when the equation of state allows it, and (d) the solution of this two-phase Riemann problem using sparse grid tabulations otherwise. The proposed computational method is illustrated with the three-dimensional simulation of the dynamics of an underwater explosion bubble.
hal-00703493 , version 1 (02-06-2012)
Charbel Farhat, Jean-Frédéric Gerbeau, Arthur Rallu. FIVER: A Finite Volume Method Based on Exact Two-Phase Riemann Problems and Sparse Grids for Multi-Material Flows with Large Density Jumps. Journal of Computational Physics, 2012, 231, pp.6360-6379. ⟨10.1016/j.jcp.2012.05.026⟩. ⟨hal-00703493⟩
275 Consultations
0 Téléchargements
