Modelling Martin Löf Type Theory in Categories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a model of Martin-Löf type theory that includes both dependent products and the identity type. It is based on the category of small categories, with cloven Grothendieck bifibrations used to model dependent types. The identity type is modelled by a path functor that seems to have independent interest from the point of view of homotopy theory. We give some examples of computations involving identity types.
IdentityTypeMyElsev.pdf (358.91 Ko) Télécharger le fichier
hal-00706562 , version 1 (11-06-2012)
hal-00706562 , version 2 (18-12-2012)
hal-00706562 , version 3 (30-08-2013)
hal-00706562 , version 4 (19-09-2013)
  • HAL Id : hal-00706562 , version 2
François Lamarche. Modelling Martin Löf Type Theory in Categories. Logic, Categories, Semantics, special issue of J. of Applied Logic, Ch. Retoré and J. Gilibert, Nov 2010, Bordeaux, France. ⟨hal-00706562v2⟩
327 Consultations
377 Téléchargements
