Modelling of the migration of endothelial cells on bioactive micropatterned polymers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
In this paper a macroscopic model describing endothelial cells migration on bioactive micropatterned polymers is presented. It is based on a system of partial differential equations of Patlak-Keller-Segel type that describes the evolution of the cell densities. The model is studied mathematically and numerically. We prove existence and uniqueness results of the solution to the differential system and also that fondamental physical properties such as mass conservation, positivity and boundedness of the solution are satisfied. The numerical study allows us to show that the model behaves in good agreement with the experiments.
RR-7998.pdf (1.79 Mo) Télécharger le fichier
hal-00709993 , version 1 (19-06-2012)
hal-00709993 , version 2 (21-06-2012)
hal-00709993 , version 3 (09-07-2012)
  • HAL Id : hal-00709993 , version 2
Thierry Colin, Marie-Christine Durrieu, Julie Joie, Yifeng Lei, Youcef Mammeri, et al.. Modelling of the migration of endothelial cells on bioactive micropatterned polymers. [Research Report] RR-7998, 2012. ⟨hal-00709993v2⟩
337 Consultations
461 Téléchargements
