Alternative Restart Strategies for CMA-ES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper focuses on the restart strategy of CMA-ES on multi-modal functions. A first alternative strategy proceeds by decreasing the initial step-size of the mutation while doubling the population size at each restart. A second strategy adaptively allocates the computational budget among the restart settings in the BIPOP scheme. Both restart strategies are validated on the BBOB benchmark; their generality is also demonstrated on an independent real-world problem suite related to spacecraft trajectory optimization.
ppsn2012.pdf (431.08 Ko) Télécharger le fichier
hal-00713415 , version 1 (01-07-2012)
Ilya Loshchilov, Marc Schoenauer, Michèle Sebag. Alternative Restart Strategies for CMA-ES. Parallel Problem Solving From Nature, Sep 2012, Taormina, Italy. pp.296-305. ⟨hal-00713415⟩
341 Consultations
367 Téléchargements
