Spectral Estimation of Conditional Random Graph Models for Large-Scale Network data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Generative models for graphs have been typically committed to strong prior assumptions concerning the form of the modeled distributions. Moreover, the vast majority of currently available models are either only suitable for characterizing some particular network properties (such as degree distribution or clustering coefficient), or they are aimed at estimating joint probability distributions, which is often intractable in large-scale networks. In this paper, we first propose a novel network statistic, based on the Laplacian spectrum of graphs, which allows to dispense with any parametric assumption concerning the modeled network properties. Second, we use the defined statistic to develop the Fiedler random graph model, switching the focus from the estimation of joint probability distributions to a more tractable conditional estimation setting. After analyzing the dependence structure characterizing Fiedler random graphs, we evaluate them experimentally in edge prediction over several real-world networks, showing that they allow to reach a much higher prediction accuracy than various alternative statistical models.
CRGs.pdf (180.06 Ko) Télécharger le fichier
hal-00714446 , version 1 (19-07-2012)
  • HAL Id : hal-00714446 , version 1
Antonino Freno, Mikaela Keller, Gemma C. Garriga, Marc Tommasi. Spectral Estimation of Conditional Random Graph Models for Large-Scale Network data. UAI 2012 - 28th Conference on Uncertainty in Artificial Intelligence, 2012, Avalon, United States. ⟨hal-00714446⟩
156 Consultations
100 Téléchargements
