Asymptotics and scalings for large product-form networks via the Central Limit Theorem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Markov Processes And Related Fields Année : 1996
The asymptotic behaviour of a closed BCMP network, with $n$ queues and $m_n$ clients, is analyzed when $n$ and $m_n$ become simultaneously large. Our method relies on Berry-Esseen type approximations coming in the Central Limit Theorem. We construct critical sequences $m^0_n$, which are necessary and sufficient to distinguish between saturated and non-saturated regimes for the network. Several applications of these results are presented. It is shown that some queues can act as bottlenecks, limiting thus the global efficiency of the system.
bignet.pdf (257.12 Ko) Télécharger le fichier
hal-00717735 , version 1 (13-07-2012)
Guy Fayolle, Jean-Marc Lasgouttes. Asymptotics and scalings for large product-form networks via the Central Limit Theorem. Markov Processes And Related Fields, 1996, 2 (2), pp.317-348. ⟨hal-00717735⟩
Collections
INRIA INRIA2
116 Consultations
56 Téléchargements
